Шаблонов: 9:
Display (default),
GenericControls (default),
TopicRating (default),
Errors (default).
bar_above,
fatal_error,
bar_below,
Post.english (default),
Post.russian-utf8 (default),
Stats.russian-utf8 (default),
hs4smf.english (default),
Файлов стилей: 4:
portal (default),
gpbp (default),
editor (default),
rating (default).
Подключено файлов: 67 - 1610KB. (
показать./index.php, ./Settings.php, ./Sources/QueryString.php, ./Sources/Subs.php, ./Sources/Errors.php, ./Sources/Load.php, ./Sources/Security.php, ./Sources/Subs-Shoutbox.php, ./Sources/Subs-Portal.php, ./Sources/LoadAds.php, ./Sources/Subs-Db-mysql.php, ./Sources/Dquote.php, ./Sources/RedirectPage.php, ./Sources/PostHistory.php, ./Sources/Subs-TopicRating.php, ./TopicPrefixBasics.php, ./Sources/ScheduledTasks.php, ./Themes/default/languages/index.english.php, ./Themes/default/languages/Modifications.english.php, ./Themes/default/languages/index.russian-utf8.php, ./Themes/default/languages/Modifications.russian-utf8.php, ./Themes/default/languages/TopicPrefixBasics.english.php, ./Themes/default/languages/TopicPrefixBasics.russian-utf8.php, ./Sources/ILA_integration.php, ./Sources/ILA-Subs.php, ./Sources/hs4smf-Subs.php, ./Sources/Subs-MobileDetect.php, ./Sources/Subs-SimpleTickers.php, ./Sources/Subs-Optimus.php, ./Sources/Subs-Scrolling.php, ./Sources/Subs-SimTopics.php, ./Themes/default/languages/SPortal.english.php, ./Themes/default/languages/SPortal.russian-utf8.php, ./Themes/default/index.template.php, ./Themes/default/languages/TopicRating/.english.php, ./Themes/default/languages/TopicRating/.russian-utf8.php, ./Themes/default/languages/Optimus.english.php, ./Themes/default/languages/Optimus.russian-utf8.php, ./Themes/default/Scrolling.template.php, ./Themes/default/languages/SimTopics.english.php, ./Themes/default/languages/SimTopics.russian-utf8.php, ./Themes/default/Ads.template.php, ./Themes/default/languages/Ads.english.php, ./Themes/default/languages/Ads.russian-utf8.php, ./Sources/PortalBlocks.php, ./SSI.php, ./Themes/default/Portal.template.php, ./Sources/Display.php, ./Themes/default/Display.template.php, ./Sources/Subs-Editor.php, ./Themes/default/languages/Post.english.php, ./Themes/default/languages/Post.russian-utf8.php, ./Themes/default/GenericControls.template.php, ./Sources/Aeva-Embed.php, ./Sources/Aeva-Sites.php, ./Themes/default/TopicRating.template.php, ./Themes/default/languages/SimpleTickers.english.php, ./Themes/default/languages/SimpleTickers.russian-utf8.php, ./Themes/default/Errors.template.php, ./menu.php, ./Themes/default/SearchFocus.template.php, ./Themes/default/languages/SearchFocus.english.php, ./Themes/default/languages/SearchFocus.russian-utf8.php, ./Themes/default/languages/Stats.english.php, ./Themes/default/languages/Stats.russian-utf8.php, ./Themes/default/languages/hs4smf.english.php, ./Themes/default/languages/hs4smf.russian-utf8.php)
Попаданий в кэш: 16: 0,00123 сек. для 145 801 байт (
показатьget modSettings: 0,00015 сек. - 60214 байт, put modSettings: 0,00058 сек. - 60214 байт, get board_parents-0: 0,00005 сек. - 6 байт, get permissions:-1: 0,00001 сек. - 152 байт, get theme_settings-1: 0,00002 сек. - 1793 байт, get log_online-update: 0,00004 сек. - 13 байт, get posting_smileys: 0,00005 сек. - 16939 байт, get verificationQuestionIds: 0,00005 сек. - 18 байт, get parsing_smileys: 0,00003 сек. - 6304 байт, get topic_prefix_7: 0,00004 сек. - 14 байт, get response_prefix: 0,00001 сек. - 7 байт, put response_prefix: 0,00003 сек. - 7 байт, get moderator_group_info: 0,00005 сек. - 120 байт, get menu_buttons--1-russian-utf8-1: 0,00006 сек. - 0 байт, get similar_topics-34537-u0: 0,00003 сек. - 0 байт, get db_last_error: 0,00003 сек. - 0 байт)
